Lift kit What else?
Loose sun visor... any adjustments?
Best Wheel / Tire Size Comparer ever.
My friend lifted his 06 4 inches in the front and 2 in the back. He also installed an adjustable track bar. Does he need to replace or add anything else to accomodate the lift? Thanks in advance.
I have a 6 inch lift and 37 inch tires. I have installed a steering box brace, the new style steering, and dual stabilizers. My next step is the Carli upper ball joints and Moog lowers. You might suggest to your friend to look into these things. Death wobble has been a problem with my truck after i installed my lift but with every step I get closer to eliminating it. A bigger set of tires is hard on the dodge suspension so these upgrades will help in the long run.
I forgot to mention he has 36 inch Toyos. I think he is in the market for all those things but i was wandering if there is something that he has to install to make it work right.
:)other than longer shocks he doesn't need anything else right away. however he might have a problem with clearence with 36s. I have a 6 inch superlift with 37s and when I set my camber caster back to factory spec they rub alot. I have a laramie so my bumper is a little lower than the other trucks but he might have to notch his bumper. hope this help if you need anything else just holla
