I just changed my stock lift pump, now relocated, started truck, and to my surprise I saw 10 psi only. After about 100 mi. I see psi dropping, fluctuating, it goes to about 6 psi when accelerating. Strange thing is it goes to about 14 when I get on the brakes. At a comlete stop, and when idling goes to about 10 again, and the same thing happens. Why it goes up when I hit the brakes?
My fuel gauge stopped working about a week ago,when I hit the bottom of tank it goes back to normal, but after driving few min. it starts dropping and gets to E. I got the new part- fuel level sending unit, and I have to install it, I hate to drop the tank. I might try lifting the bed. I'm thinking of changing the supply line to the LP with 1/2" hose as well. I will look inside the tank to see if there's any junk, that might be causing pick-up problems.
Did any of you experience similar problems. I can't believe I was carring with me a bad new Carter pump from Cummins
Thanks for your help.
Ilian
Ilian
