My 98. 5 with 95450 miles was doing fine until I fixed it. LOL I am stock. I put a fuel pressure light on the dash. It goes off when the pump comes on and stays off even with WOT up hill. I desided to put a pusher pump on too. It is back by the fuel tank and wired into the stock lift pump. When I finished the job I primed it and started it. Well the lift pump was leaking like a sive. It appeers to be leaking from the three mounting bolts. If I disconect the new push pump the leaking stops. The lift pump is running, I can hear it, but no leak. Turn on the pusher pump and it leaks badly.
Any ideas? Tomorrow I will take it off and tighten the top cover. If that does not stop the leaks I will bypass it. What do you think?
Thanks
Chris
Thanks
Chris
