My truck won't start, found the lift pump not putting out any pressure. Changed the pump (foolish mistake) without first checking voltage to the pump. I'm only getting 8.6VDC to the pump. The manual says that the ECM controls the lift pump, but I would think that would be an on/off thing. I didn't see anything in the schematic that would restrict voltage. Checked all the grounds and connections, everything is tight. Am I looking at replacing the ECM or can there be another cause? It's a '99 with 130K, MBRP 4" exhaust, Airaid intake.
