lift pump pressure testing
Turbo Charger Sound....?
Got in an accident today
I aquired a 99 2500 with 36k miles a few weeks ago. After reading the posts about the failing lift pumps I decided to test the pressure. Where can I find a pressure guage to test with and can someone give me some basic instructions as to where to test and what to look for?
99 2500 Laramie SLT 4X4 QC auto 3. 55 LB stock (for now)
Here is a picture of the fuel pressure gauge that I bought at the local parts house, screws right on to the test port. There is a plunger in the center that opens the schrader valve.
Attach to test port.
Bump starter, do not start engine,this starts the 30 sec cycle of lift pump and you should read pressure of 14 PSI.
If hose was longer could lay up on windshield and take for drive.
Every vendor seems to be backordered on the electric gauge so I bought this for my piece of mind.
Hope this helps,
Steve 2001. 5 QC 4X4 LB
Check this link out Steven. I think it will answer any questions you have.
https://www.turbodieselregister.com/ubb//Forum4/HTML/004735.html
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Stewart Warner Fuel Pressure Gauge with dual senders, Westach Oil Temp Gauge for differential. Rancho 9000's shocks, PowerEdge EZ Box, Amsoil foam air filter and synthetics in the motor and differential. Cummins Power, don't leave home without it
