Let's talk facts not Engineering theories
Fact: cheap well pumps suck from shallow wells, deep wells get submersable pumps which PUSH the water to our homes.
Fact: Gasoline fuel injected cars that had remote fuel pumps that sucked from the tank had high failure rates [VW rabbit,Jetta, BMW 320 etc].
Fact: the new versions of the above cars have in-the-tank submersed PUSHER pumps that last virtually the life of the car, unless they are fed contaminated fuel. And this is with Gasoline which has very little lubricating ability compared to diesel fuel.
Fact: My virtually dead second factory lift pump [o-7psi at idle] came to life and survived another 7000 miles when fed fuel from a frame mounted pusher pump. It was fed 7psi, and in a few seconds would wake up and run the pressure to the top of the gauge 17+psi. Once the pusher pump was removed for some warrantee work, the factory lift pump was DOA within five minutes at the dealer. It was warranteed, I'm now on my third lift pump in 21K miles.
Fact: in every aircraft that I'm type-rated in that uses hydralic pressure, [to operate various systems] has hydralic oil supplied to the electric or engine driven hydralic pump UNDER PRESSURE. It is proven that if the supply oil looses it's head pressure, the pump will fail almost immediately.
Fact: I don't believe that there has been a failure of a factory lift pump when it has been fed fuel by a pusher pump. There have been untold numbers of factory lift pumps fail when run in the stock configuration [sucking fuel uphill from a tank 6-8 feet away.
The bottom line: with the expense and fragility of the VP44 hanging over my head, I will continue to keep a pusher pump feeding the lift pump.
Last fact: Engineers 'engineered' this setup, with some help from penny pinching marketing and accounting at Dodge.
Theory often is not supported by reality once the parts are on the road and failing at a high rate, then new 'theories are created' to cover the 'new reality'.
Road tested and proven beats theory every time.
My opinions and experience: Greg L
