Gary - K7GLD said:On my pump that I sacrificed for the cause, I used a bench grinder to grind away the place where the motor housing crimps to the lower rotor casting - and when you open the 2 resulting halves, the risidual fuel that hasn't already drained out of the motor pours out - and there's CLEAR evidence inside that there has been steady fuel flow thru the motor section, among other things, it as clean as new, NO dusting of wear or brush particles, etc. ,
Oh, and remember, there's that open passage/port I pointed out between the rotor outlet and the motor - so MOST fuel will simply drain out of the motor section when the pump is removed from the engine and lines - and GUESS where those particles DO end up in normal operation after being flushed thru the motor by bypass fuel flow...
The fuel filter!![]()
Pays to have a good one, and changed regularly too, right!![]()
OH - the pump I destroyed was given to my by a member here who had well over 100K miles on it - look here at the brushes:
And of course, how CLEAN it is in there after a steady diesel flow thru it!
I know Gary is correct about the pieces of the pump ending up in the filter... we changed the old man's filter this past weekend to find the bowl full of brass, copper, and aluminum flecks... this is running one of the newer "campaign" pumps... but it still puts out good pressure...
And I don't see the issue with running fuel through the motor... it would serve to lubricate and cool the electric motor... not a bad design actually...
I plan on completing the relocation on the old man's 99 the next time the LP dies... he's on the 80k cycle with the next replacement due at 320k!!
steved
