In reading the TDReSource in issue 58, I took interest in TSB 03-003-06, Axle Fluid Level. There is a note at the end of the TSB the reads no friction modifiers are required in the limited slip rears. I own a 2003 CTD 3500 4WD QC (purchased 12/02)with a limited slip rear. During my first fluid change (30k), I did not add the friction modifier as it was my understanding it was not required. Shortly thereafter I began to feel a "grinding" in the rear of the truck, typically when starting from a stop while turning. I stopped at the local dealer and was told as a matter of routine, they always add friction modifiers to the limited slip rears. I added the friction modifier, which fixed the problem. I have added the modifier on every fluid chage since, with no problems. Has anyone else had this problem? Was this an early make issue that was corrected. I used Amsoil on that first change and was wondering if that had something to do with it. Just curious.
Kevin McD.
Kevin McD.
