Little Lights behind heat controls ?
Sudden drop in MPG, any suggestions...
Putco Box Rails
The little lights that light up my hot-cold nob is out and the one behind the vent option nob is out. Is it real hard to take off the center dash cover to get those bulbs ? And does anybody know what part # for those little lights ? Thanks
I had mine off to install xm radio. First, unscrew the little hanger on the passengers side to the left of the glove box. Then grab the panel on the drivers side bottom and pull (it basically extends from the steering column to the glove box). You may need to pry it out slightly. It is held in place with press fit pins. work your way around pulling the pins loose.
Don't know the part #'s, but hope this helps.
