Re: Why is it OK on their big diesel engines and not ours?
Extended idling of your Cummins, even after break-in, results in what is called washdown. Low cylinder temperatures cause incomplete burning of the fuel which washes down the lube oil from the cylinder walls and can dilute the oil with fuel. Not a good situation. Trains probably get away with it by running at a higher rpm idle and you can too with a high idle kit on a 24 or even just a stick pushing in-between the throttle pedal and seat on a 12.Originally posted by RADdodge
what is wrong with idling a Cummins for extended periods? I see that Cummins only recommends idling for no more than 5 minutes during the break-in period. (They state that the break-in period can last from 4,000 to 20,000 miles depending on usage. ) So is it ok for extended idling after the break-in period?
