I'm trying to figure out if it is an injector or maybe a leak in one of the lines. If I need it to start all I have to do is crack one of the lines on the rail and the beast fires up. I am going to pull the rail off one more time, re-torque the tubes, and banjo nuts. I did speak with a Cummins tech and he said if the check valve on the rail was bad that I could not touch the fuel line it would be that hot. I drove the truck around for an hour and it was cool to the touch. I will follow up tonight. Thanks for the advise.
