Long idling....bad?
2001 deletion list
how do you guys flush out radiator
Cummins states not to let your new engine idle too long. How long is it new? How long is a long idle? When I go through a drive through and it's going to be a long wait, should I shut it off or let it keep idling? I feel that turning it on and off isn't good either. I have 3000 miles on it so far. Any info would be great. :confused:
I remember reading that you shouldn't let a 24 valve idle more than about 5 minutes... the cooling system works too well, and it will over-cool, possibly allowing some fuel washdown of the cylinders.
Several ways to combat this... install an e brake and turn it on. Or you can install a fast idler... I believe Practical Solutions makes one.
I doubt with the constant movement of a drivethru that you have a problem there. It is more of a problem of a steady idle.
Hope this helps to explain it a bit!
Practical Solutions does make a High Idler. And yes, 5-10 minutes tops for idleing. Especially in cold weather unless you can increase the RPM's, with... ..... I high idler?
