The '95 would be the 12 valve engine, and with the automatic either 160 horsepower to 175 or 180 max, I'm not sure. If the engine is still stock (no injector pump tinkering) the transmission should be in good shape. Check the color of the transmission fluid. If it is nice and red like new ATF it should be okay. Whatever you do give it a thorough test drive and see if it shifts properly. A motorhome on a truck chassis is like being fully loaded all the time, so the 32,000 miles would not be the same as a pick-up with the same mileage. If you buy it and it does not already have one, install a transmission fluid temperature guage, and drive so you keep it cool. If everything checked out and the unit was in Washington state, I would need to have someone slap my hand or I would be driving it home. From my experience pulling a camper made from a motor home (prev. owner wanted the truck, I got the unit for $600. 00) you should get around 12 mpg if you cruise below 65. Enjoy. Brad :-laf
