Looking For New Air & Exshaust Systems.
Where to get service manual
Silcone Hose kits....need help.
HELP!! I've Been BOMBED. I've installed a EZ PRO COMP. and cannot belive the differance,It's not the same truck. I'am hooked.
Now I'am looking for a Air Induction System (what's a Scotty?)
I see alot of differant filters whats the best?? Also a 4" exhaust, and DDII's.
I know the next thing will be the clutch.
With the EZ on 5-5 and under WOT I can feel it slipping.
Just installed
I just installed the Cold Air Kit from Jannetty Racing. I highly recommend it. It's really just a great product, plus I have never heard my turbo spin up so quickly...
Air Filter and Exhaust
Hello, The best bang for the buck in airfilters is the BHAF: Big Honkin' Air Filter. It is a simple install, with no cutting, drilling or added noise from the turbo. Do a search for BHAF, there is a lot of reading material. There are several suppliers for this filter. about $39-$50.
If you like noise, then go with the Pscotty air induction system, it requires cutting a large hole in the firewall of the cab, and that gives a virtual direct line for noise to the inside of the cab, some have reported that the turbo then resides in the glovebox. :D However that is not for me! [see my Sig. ]
There are several good exhaust systems available, but there is a noise issue again. Some 4" systems tend to have a 1900-2100 rpm drone that reverberates inside the cab. Most people find it quite annoying. I just removed the muffler, and left the factory resonator, added an additional used 3. 5" resonator, and 4" tailpipe. It sounds a bit louder, but very little drone inside the cab.
Have you joined the GLTDR yet?? The 23rd of this month is a bombing get together in Maccomb. You may want to check this out.
I didn't see any gauges listed in your signature, I hope you have a fuel pressure and EGT guage as a minimum, with the Comp cranked up, high EGT's are guaranteed with stock intake and exhaust.
Good luck, happy HP hunting :D Greg L
