John
Q
Pit Bull, is it the bolt or (and?) the female thread in the frame cross threaded?
I would think it would be the frame or both because the metric bolts have a strength rating of 10. 9 which is almost equivalent to our grade 8 (ok, ok, it's a little less)... both being harder than the steel in our frames.
Matt, I was worried about what forces the sway bar might impart on the compromised mount. That's why I think it's imparative that all four bolts be properly installed.
Besides, Pit Bull doesn't even have one of the two mounting ears flush against the frame (on the side that has the semi-stripped thread).
One other thing Pit Bull, I'm wondering why both mounting ears are not flush against the frame. Did you start all four of the bolts and progressively tighten them, finishing off by torquing each of them or, start one bolt and subsequently tighten that bolt, moving onto the next one? The former is correct (IMO) the latter is a recipe for disaster (IMO).
At any rate, the OE sway bar bolts were "special" in that the ends of the shaft had a pilot to locate the threaded holes more easily and positively than the longer equivalents provided by Darin.
I know one thing though...
I RE-installed my steering brace this weekend after having the main structure powder coated (plus I painted my bearing assembly to match... PPG gloss black) and found I hadn't fully checked EVERY aspect out beforehand (
) To properly center the large hole in the steering brace to the replacement nut/bearing shaft, I had to "open up" the four mounting slots (long side of each of the four slots nearest the box tube bar) with a die grinder and carbide burr in order to keep the ID of the large hole from rubbing on the "point" of the hex. I'm not really sure what happened, as I KNOW I checked for that. All I can figure is that I spaced, had the steering wheel turned a little bit [my front-end was in the air, on jack stands with no tires mounted] and noticed that it was relatively centered (
) using a flat of the hex as a reference as opposed to the point of the hex.
