I finally got chance to look around for the fuel return line and it looks like everyone was correct, my loosing prime probably due to fuel return line. I could see a drop of fuel on the hose close to the fuel filter.
My question is what size fuel line do I need? I could not find the lines by starting at the engine so I followed the lines from the tank. There are two metal lines along the frame, one is a larger diameter which I assume is the intake and the smaller being the return. I could see where the metal line connected to a standard rubber line went along side the block behind the fuel filter and connected another metal line with a standard screw hose clamp.
The problem is it is extremely difficult to reach, I was just barely able to touch it from the engine compartment but still could not see it. It looks like I can replace it when I swap out my fuel filter but I prefer to have the correct size line before I start. Worst case I can buy several fuel lines to make sure I have the right one.
Anybody have the correct return fuel line? Any other words of wisdom?
96 2500 extended cab full bed with a cap and running boards. 100% Amsoil with bypass oil filter. Everything else stock except bypassing the RWAL (rear wheel antiloc) operation so the truck will now stop when i hit the breaks without turning my hair white.
