Update on the continuing saga of.. "The truck won't start".............. Yesterday I installed a new set of 24 valve injectors from the Diesel Speed Shop, and they were set to VE pop pressure. While I was swapping them out, I chanced the o rings on the connector tubes, and the tubes showed no wear on the tapered tip. I did a little tuning on the pump, after I got the truck started. It took very little bleeding of the lines to get it running. I was pretty hopeful, until this morning. It still won't start. It hits several times, and the white smoke is still rolling. One thing I noticed is, if you keep cranking, it doesn't seem to hit much, but if you let off the key, and crank it again, it seems to hit each time, but doesn't start. The injectors I ordered were 100hp/200 torque injectors. I was really impressed with the truck, once it starts.
SO: New Bosch VE pump, new injectors set to VE pop pressure, new o-rings on the connector tubes. FASS pump at 11 psi. I can't see any leaks anywhere.
Ideas, before I have a bonfire??? This thing has me beat down.
