Ok here's the deal. I am cruising down the interstate (unloaded). Cruise set on 70. Then i notice i'm slowing... I look at EGT it is normal 5-6 area. Boost is mear 10psi. Temp is normal. Pedel is to the floor! So I knock the cruise off push in the clutch, and hit the pedel. It comes back to life and resumes normal conditions. Then only thing that I have noticed is that it only happens when I'm down to about 1/4 tank of fuel or so. I don't see where that would cause a problem. About 20k ago i replaced LP and vp. I popped the test port on the fuel filter and get a steady supply of fuel.
Any ideas would be great!
