lost another motor
What is the Tool for fill/drain plug 6spd manual 03
Holes in AFE Stage II "S" pipe...
You are one that does not learn from your first blow up! I hope you learn from the second one. That is why they have a red line on the tack! It is not a gas rig.
he'll learn from it... he'll probably find it was a valvetrain issue...
"tack"? like a thumbtack?
my first 12 valve didn't even have a tachometer, but it would only turn about 2500rpm tops... meanwhile, a set of decent valvesprings and governor mods, and a 12 valve will turn 4,000+ rpm safely... hmm...
if the truck was perfect from the factory and there's no way to improve it, then why do you have a list of mods in your sig? :confused:
:-laf enough said.....
[/ATTACH] pulled the valve cover this morning and only found a bent #2 exhaust rocker push tube and the bridge laying inbetween the springs, valve stem height looks ok so i dont think the valve seats or valves are damaged, i think i will detune the smarty rev limit down to 3500 and pull the head to check for other damage... :cool:
