:-laf If it wasn't for dealing with the weather you have I would be up there working in your industry
Bob
just need alot of clothes and heaters and fire
Bob
You are one that does not learn from your first blow up! I hope you learn from the second one. That is why they have a red line on the tack! It is not a gas rig.
he'll learn from it... he'll probably find it was a valvetrain issue...
"tack"? like a thumbtack?
my first 12 valve didn't even have a tachometer, but it would only turn about 2500rpm tops... meanwhile, a set of decent valvesprings and governor mods, and a 12 valve will turn 4,000+ rpm safely... hmm...
if the truck was perfect from the factory and there's no way to improve it, then why do you have a list of mods in your sig?![]()
If the bridge and rod are bent the piston must have hit the valves. I can't think of anything else that could have done that.
I'd be nice to know what the valve springs pressure/#'s where on this motor.
I'd be nice to know what the valve springs pressure/#'s where on this motor. <!-- google_ad_section_end -->
