Thank you, those were the two answers I have been looking for. I just thought I had a bum truck from everybody elses comments on this board. At least I have tested and checked everything on the truck now
I have a bearing kit for the getrag bought already and want to get it dropped out in the next month. That is 1st on the list.
Next what do I do to make it pull. My goal: I was planning on buying a 26" gooseneck, put a slide-in pickup camper on the front of the trailer, and put my jeep on the back. The new offroading rig will weigh in at around 5500lbs, camper most likely 800-1000? (really haven't checked on that yet), + the weight of the trailer. Sound feasable to use this truck for that purpose, or should I get out now?
I would be very happy right now to be able to tow like my dads stock 02. It is the standard output engine. It has no problems pulling a stock trailer loaded to 20K lbs down the highway easier than I pull 5K.
All my mods are in the sig, they money I spent was buying the truck and not having it pull as well as the $750 truck I had at home.
How much money in upgrades is this gonna cost, gotta put that in the budget. Sounds like it is harder to get the power to where you can use it if you use the truck for pulling a load. The guys who just play with their trucks don't seem to have to worry as much about EGTs.
JRussel:
In colorado I don't know where the EGTs would have stopped at. I would drop to 4th and get my rpms up on the govenor before hitting the climb keeping out of the trottle as much as possible. After a mile or so I had to start lifting my foot at 1250EGT, once it was pulled down below 1700 rpm I would goto 3rd and it would stay at 2300rpm, 35mph, 1000-1100 EGT and there it stayed until I found some downhill stretch.
Here in KS there are several hills on HWY36 I drive that can make it hit 1250 and pull my speed down below 50mph if I don't shift down. Usually now I just drop it to 4th when the speed gets under 60mph.
Andy
