2nd Gen Non-Engine/Transmission LSD question
2nd Gen Non-Engine/Transmission Bad AC compressor
2nd Gen Non-Engine/Transmission time for new tires
RBeard
When I turned into my gravel driveway, I noticed the inside wheel tearing up the gravel like the LSD is engaged. Is this normal or a problem that I need to address with some sort of Maintenance.
235k on the clock with fluid changes (Royal purple) every 50k
Normal, the clutch type LSD's will always slide the tire on surfaces that don't provide solid traction. Thweight is always to the outside on a turn so it slides the inside tire. Does it on dusty pavement too.
