four ounces of Lucas fuel treatment went into the def.will it damage the def injector?
Attention: TDR Forum Junkies Doubt it will damage the injector but very likely could damage the SCR cat or the rear NOx sensor, possibly the DEF pump.four ounces of Lucas fuel treatment went into the def.will it damage the def injector?
It can cause the DEF to gel and cause all sorts of problems. Sometimes. Many times. Most times.
At the very least, you need to pull the tank and rinse it, IMO. Soon. Distilled water will work for the rinse cycle.
I just deleted mine and put the EPA on my Christmas Card list.
right
I'm not a mechanic, so it looks like a big job to remove the tank,could I put dish soap and fill and drain again, I'm working in my driveway. Thanks.You really need to just pull the tank and clean it correctly with soap and water. They make test strips that detect hydrocarbons. I used to carry them when I was still working and suspected a contaminated DEF tank.
No you can not- that thing needs to be Clean-Clean, not sort of somewhat cleaned.
That tank needs to be removed, thoroughly cleaned and dried.
There is no work around for this procedure.
Thank God you didn't switch the ignition nor started the engine- otherwise it would have cost you thousands of dollars.
Haven't seen any.Are there any threads on how to remove the def tank?
Thanks ,Ron, I have been watching everything on u tube,thinking about doing a delete, too many def problems.Try YouTube to see if there's a how to on removing it. A lot of serious deleters out there remove all the emissions related part. I searched and see several videos.
Good luck with your project.
Cheers, Ron
Too many DEF problems?Thanks ,Ron, I have been watching everything on u tube,thinking about doing a delete, too many def problems.
