Hohn said:
Yes-- 7. 5mm plungers on the SO vs 7mm plungers on the HO.
Smaller plungers in the injection pump & smaller injectors, yet the ETH makes more power?! What besides the higher compression makes that happen?
Aside from that, it's just software. The HO is programmed to use more of its potential in stock form.
So, if 63% is max fueling of the VP, then the SO might use 30% in stock form, and the HO might use 38% (fictional numbers).
Thus, there's less "untapped" potential (pardon the pun) with a fueling box on an HO. That's why a Comp that gives an SO 120hp or more, only gives an HO about 85hp-90hp. The HO just has less potential, and it's using more of it smaller quantity in stock form.
In stock form, think of the SO as a bodybuilder benching only 150lb when he COULD bench 500+. Think of the HO as a smaller guy benching 180lb, when his max is only 300 or so.
One is clearly operating closer to his limits.
jlh
