Scott, thanks for the pic. I would add if you use a prefilter for the bhaf, definately dab some silicone over all the exposed bolt heads that the prefilter comes in contact with, as they will rub a nice hole in the prefilter. No problem if no prefilter as the bhaf is a tough wire mesh that aint gonna wear a hole in. Your mount will also keep the bhaf from flopping back and forth, working its way off the intake hose, which is will do very readily if you do like I did and sit it on the fender. A must for newbies reading this, is a 4" clamp or 4. 5" if theres such a clamp for the filter end of the intake hose. The oem 5" bottoms out and it can be tough to keep the neck of the bhaf tight and connected to the hose. I seemed to never have a problem with the nonIC'd hose but the IC'd hose likes to come loose, so one should inspect it time to time. But since I've ordered a ASA intake to attach to my bhaf, hopefully no more problems of the filter coming off.
