It took about three of them before I perfected one. I took a mild steel dowel pin. I cut it to about 3/4 inch long. Then deburred the edges. I asked one of the tool makers I work with for his smallest drill bits. Wow they were small. Slightly bigger than a human hair. I broke the first bit. But the secound one I was more cautious. I cleaned and blew out the tiny hole in the pin. Then Installed it in the rubber hose near the afc. I put a small radiator clamp outside the rubber hose and then squeezed it to ensure the pin will stay put and seal it up good. How does it perform. Well boost really jumps up fast but will fall back some. but by that time you should be in the next county.
95 Dodge Ram reg cab,2500,5spd,Tweaked & Peaked Cummins Diesel, MODS, K/N filter,dual exhaust 5'' tips,Lost muffler,turbo silencer, ACCESORIES,ISSPRO turbo & pyro. gauges. Shell Rotella in pan. Fleatgaurd filters. 140k. on the OD.
If you can smell this message. I Farted
