MagHitec - Oil Drain Valve
Changing oil too soon is bad??
Vp44 injector pump
Ozymandias
I searched a long time for it.
Transmission Oil pan drain Valve.
It is metric M22x1.75
I wrote an Email to Genos some time ago but they weren't interested in that information.
I didn't even got an answer to my mail.
So if you want that Valve then ask them for it, with enough people asking they may start selling it.
http://www.nexusparts.com/m22x1-75-femco-standard-sb-drain-plug
( For search engine mag-hytec )
Ozy- I've got a Femco on my oil pan and the last time I changed the trans fluid I was wishing there was a Femco plug for the Mag-Hytec. Thanks for doing the footwork. Or I guess fingerwork. :)
Whats the difference between that and the 22mm Femco plugs Genos already carries?
https://www.genosgarage.com/product/ez-dp-22mmpl-dg/drain-valves
Odd how they just did not try to sell you one of those. Threads are threads, from your link there is no pic of the valve to compare.
I was looking at my Goerend pan tonight on my 47RE build, that thing is a beast of a pan, I did not actually filp it over to look at the drain, but my guess is would be a few minutes for them to tell me the thread size.
Genos is M22x1.5mm for example that fits for the TCs Drain Plug.
MAG is M22x1.75mm what is pretty exclusive pitch that only they use.
Got it yeah did not mention pitch on their oil plugs, will check my pan and see what it looks like. I'm a few weeks out still till I finish my build. I won't be putting that kind of miles on my truck to use one on the trans. I have one for the Oil.
Agreed. I won't ever use/install another transmission pan ever since the first one a few years back.
