When You produces millions of Engines, Your maintence recommendations will be worst case scenario, The maker has no idea on storage or use. We store our 4-stroke snowmobiles in the trailer during the off season April-Dec, I was going to change the oil Sch-9000 before the last season, just for SAG I pull samples and off to blackstone ,Hu ha after 5 years all was still good, I will change them all this Dec before the season. By the way they both hold 3.5QTs, It takes 1.5hrs Per machine to LOF, the filters are buried and you must remove the bulk head cover to reach the crankcase drain plug, the Auxiliary Reservoir is not problem.
Oil service is open to the owner, Some think its the ONLY maintence necessary, We had owners coming to the shop that service oil every 3K, on a rolling dumps in need of $3K+ in maintence... that fresh oil won't know what to do when it get in there surrounded by poorly running engine.
Now I'm really going to PO some, the same maker may state the trans fluid is good for life, go figure, that puts a big hole in the engineering subjective point.
