Lift pump went out last week so I went to Cummins bought new one and put on myself. Truck has ran great for a week, then the other day I had to crank for a second or two longer to get her started. It has done this to me a couple times, seems like it is losing its prime. Then the other night she stumbled and cut out a few times when I was accelerating. A time or two it got to 2200-2500 and wouldn't go no higher. THen yesterday I went to a festival and when I came out, I cranked for about 5 minutes of of and on cranking, finally held my foot on the floor and cranked for about 25 seconds straight and it started. Then twice last night after sitting for 15 mintues it did the same thing and when I cracked my #1 injector line at the block I had air. On the way home the I was driving normal and any hill I went up or and load that was put on the motor made the truck start stumbling and cutting out. I was driving normal holding steady rpm and every hill I went up made the truck do this. When I got home I shut it off and immediately tried to start it back up and nothing just cranking. I have checked all fuel lines around lift pump block and injection pump and they all are tight no leaks. I am so frustrated I do not know waht to do. I need some help and assistance please. I have Edge Drag Comp, Anti De-Fueling Device, Injectors, and a few other things. THanks in advance.
