Here ya go.....
Jetpilot, I did my Mallory 4140M installation a little different than most.....
1) As I have a Transfer Flow 54 gal. replacement fuel tank (which comes with approx. 14" long supply and return hose extensions that connect between the fuel sender and the short, formed OE plastic lines on the frame), I elected to mount my Mallory 4140M to the outside of the frame (thanks to Bill Kondolay's suggestion
). It is located only an inch or two forward of the centerline of the fuel sender and is protected by a nearby body mount ear welded to the frame rail. Additionally, I used a 1/4" thick piece of urethane between the pump and frame to isolate noise transmission. I drilled and tapped the frame and utilized four 5/16" stainless steel Allen head bolts that I drilled for safety wire to mount my pump... the safety wire eliminates the possibility of having the very low torqued bolts from loosening (if safety wired properly).
2) I removed the supplied Transfer Flow extension hose (supply side) and reused the quick disconnect connector at the fuel sender end, attaching it to the -06 AN Aeroquip AQP hose with an all-stainless steel worm clamp (all other "end" fittings were Aeroquip -06 AN AQP fittings). The other end is attached to a System 1 billet aluminum filter (used as a prefilter... it has a high flow, pleated stainless steel, 30 micron "screen" type filtering media). Mallory requires a prefilter with a maximum filtering media of 40 microns. A very short -06 AN AQP hose connects the output of the fuel prefilter to the Mallory 4140M. The System 1 prefilter was attached to the frame with a trick, high strength black composite plastic clamp used to mount a D-cell Mag-Lite flashlight. . it fit perfectly (it always pays to keep those trick little gadgets you never use for their intended purpose).
3) The output side of the Mallory 4140M utilizes a single length of -06 AN Aeroquip AQP hose that terminates at the inlet side of the OE fuel filter.
4)
IMPORTANT NOTE: If the AQP hose (braided stainless steel jacket) is utilized throughout,
ANYTHING it comes in contact with
MUST be protected! If not, you will quickly see how adjacent material removal can ruin ones day!
5) I removed the OE lift pump and the lift pump mounting bracket... that is, until I saw it doubles as a block off plate for the hole in the block which is utilized by the 12v mechanical fuel pump
(PS: there is a gasket between the lift pump mounting bracket and the block). I decided to modify the OE lift pump bracket, removing the "top" mounting platform (and of course, detailing it
6) I purchased a Painless Wiring Electric Fuel Pump Relay kit (purchased from Jeg's), mounting this in a project box (purchased from Radio Shack), in turn, mounting this to a nearby bed cross brace using neoprene to isolate the box to prevent any kind of noise. The project box is further protected by the back of the cab... which extends well below the level of the underside of the bed box. The supplied P. W. 30 amp circuit breaker was replaced with an 8 amp counterpart (purchased from NAPA), thereby eliminating the supplied 7. 5 amp slow blow fuse from Mallory
(my entire plan was detailed to a Mallory Tech. who, after knowing this was a dedicated circuit, approved it). Ten gauge wire supplies power to the circuit breaker (mounted near the PDC) and the P. W. relay.
7) The OE lift pump connector (pump half) plus wiring was extended, spiral wound and bound for interference protection and protected with split loom, terminating inside the project box (this is the trigger for the relay).
Also noteworthy: all connections were soldered and
double shrink wrap protected. Split loom protects all wiring in the system. Fault diagnostics due to shoddy workmanship is not something I like to be a part of. To finish off the project, I blew out the length of "unused" OE steel line, capping both ends with appropriately sized plastic caps. The extremely small amount of remaining fuel within the line should not present a problem should I (or someone else) want to reuse this line.
Jetpilot, I'll bet this is more information than you really wanted to know.
