Ben Stair I package them as single coolers also. The ford zf six speeds uses part # (1fc375) which is a single cooler. That would work as a single for the NV 4500. A single for the NV5600 would take the (1fc300) that's the short single instead of the short set which is part number 2fc300.
Here's how I package them
Part #
1fc375 - NV 4500 Single, Fords ZF 6 speed single
2fc375 - NV 4500 set, Fords ZF 5 speed set
1fc300 - NV5600 single
1fc250 - Tranfer case single
The first number in the part numbers represents the number of coolers
The last three number tells you how long they are.
Example: The 1fc375 contains one cooler and is 3. 75 inches in length. and the 2fc300 contains 2 coolers and is 3 inches in length.
Thanks Ben, I should explain these things better.
Verlyn
Part #
Verlyn
