- "Okay so you start applying service brakes, and the Max-Brake smoothly and simultaneously applies trailer brakes. Your at 45/55, now you apply the exhaust brake, so your at 54/55. The truck is braking harder, but the trailer isn't slowing with it's same authority over the truck. So now you reduce the truck brakes to get back to the 100% braking required, and you are now at 50/50 and have a lower ratio and lower overall trailer braking, even thou the truck is still at the same amount of deceleration. "
I m not sure I understand the above, When I decelerate, I come off the throttle and the exhaust brake engages and I do nothing until I either accelerate or step on the brake, if I wish to continue the slowing process I will eventually use the brakes, as I posted above this is how I drove during my trip, there was no jerking the whole unit, Truck and Trailer would slow to a stop if that was the requirement. I'm not going into the science of the Max-Brake as I don't fully understand it. I bought a Max-Brake because this is my last episode in traveling and I just wanted the finest product out there, I had a Inertia controller I removed and it worked OK but you always had the jerk when the trailer brake came on, The Max-Brake is an expensive option, is it necessary, no the others work, I'm not trying to sell everyone on it just add my experience, hope this helps.
