DaveHess
I installed my MaxBrake Saturday night. Really not difficult at all. Haven't hooked up a trailer as the driveway to the trailers has about a 3 foot drift across it. I tried hitting it with a snowblower and it just wasn't up to the task. Even a buddy with a small skid steer had a difficult time with it. No where to put the snow. I'll have to wait a couple of weeks. I mounted my controller on the left side of the knee bolster as oppossed to the pics above where it is on the right. For me it made a cleaner install with the wiring. The controller lit right up, cal went as advertised, and it went into sleep mode after about 5 minutes. Woke it up by manually operating the controller and it went to sleep again after about 5 minutes of inactivity. No leaks from any connections. I made a small pad from roll bar padding and placed the pad between the brake line leading to the sensor and the top black hose that runs next to the master cylinder. It was a slightly tight fit which was I wanted. I then zip tied the brass fitting connecting the sensor to the pad and that should take car of any vibration that brake line may have encountered. Mainly as strain relief. Can't wait to tow with it now.
