ok, I tested the connection put test light to thin wire and blue wire and they worked as suppose to with key in start and run.
tested blue wire from battery all the way to the connection.
then I took orignal relay out of the black plastic housing, so as to see internal parts. when I squeeze the contact the solenoid pops
right up. but if I don't squeeze it doesn't pop.
one thing I noticed is relay gets hot when holding it,"I assumed"
thats normal.
so if the test light works with run and start, what the heck can it be now.
thats normal.
