Message Center Lights stopped coming on? ?
Another 1st Gen rebuild
See what you guys think of my purchase
Hey Guys, i purchased my 1993 Dodge 250 about 2 weeks ago and everything on it was working great!. This weekend i decided to detail the undercarriage and also changed out new headlamps, and changed out about six burnt bulbs in the blinkers, side markers, and cut out the bumper light units and spliced new ones in it. All the bulbs work great but through the whole process somehow it seems i lost oower to my message center cause now none of my bulbs in there come on. The water in fuel, the wait to start ect... I'm not sure if accidently disconnected somthing to the unit cause i doubt all the bulbs would suddenly go out. Can any of you guys that are more familiar w your truck key me know what i can check to make sure I'm getting power to the unit? ?? Thanks in advance. Daniel-
Did you check the fuses ? Also if you power washed you might have got the connection dirty get a can of connection cleaner and clean each connection you can also check with a test light
Hey Donovan,
I did check the fuse... seems to be the same as the buzzer and Gauges wich all seem to be working.
Where can i find the connections so i can try to check those??
Water in futel is at the fuel filter ,easiest one to check ,does the 4 WD indicator work that's at the t- case on top ,on the wait to start due you here the hmm of the grid heater and the clunk noise ? The grid heater sylioniods are on the drivers side fender well
