acook said:Could Mr. Meacham, Mr. Underwood or anyone else please tell me what the front axle nut torques to on a 03 3500 SRW.
I called Dodge and they said " All you can get, plus some". What a professional answer.
Joe @ underwood tireCarney, The easiest way to get it out is an offset pick and a screwdriver. Need a pick to pick it up so you can get a flat head screwdriver under it. Then use the pick and the screwdriver to walk it around and out of the groove that it is sitting in.
It can be done with 2 small screwdrivers, but it's a piece of cake with an offest pick (one with a crook in the end of it shaped like an L or a C)
Hey Wade or Hans... . do you know where any 2 pill mobile linears might be?:-laf
I know where a 200 watter is one bill will get it it think. Painter tested it last fall and we hooked it up for about a month and its set on a shelf ever since.
I got a cobra 148 gtl tuned and peaked with a little 250 black box if anyone is interested, got the roger beep and talk back and echo installed also
Eddie
Hey Markie Mark, who done your o rings and what did it run you?
