I am posting over here in the towing and hauling forum as this thread might be of most interest to the silent majority and we'uns who burn the most fuel. The majority of diesel owners do not increase the HP of their engines (BOMBing)or just do a modest increase. I would separate the BOMBing factions into less than 280 HP and greater than 280 HP. We of the modest BOMBs just want a reasonable performance or towing ability without equipment failure. The other faction of BOMBing is into drag racing, sled pulls, dyno bragging rights, etc. and pay for the fun with busted parts. The high performance faction develops the BOMBs that we can put into use. Cam plates, electronics, injectors and transmission improvements can be used by all. But, I am not looking for further HP increases, I am looking to increase my miles per gallon.
In the past I thought that that air flow improvements with exhaust and air filter changes would have no benefit to us old farts pulling our RVs in the right lane. We go down the road at 60 with 10-15 lbs boost and get 10-14 mpg. The recent thread on "565 hp with smoke control" ( https://www.turbodieselregister.com/forums/showthread.php?s=&threadid=29453 ) leads to the website http://www.dieseldynamics.com/ . This website shows dyno 24 valve runs with stock cam and a modified cam. The dyno run shows a modest increase in HP, 10-15% . Also on the website is a claim that the cam also increases milage by 3. 8 mpg. At first I took the milage gain to be snake oil. Then I was mulling why a HP increase when the 24 valve engine computer would not have increased fueling? I finally recalled from college days 40 years ago that diesel engine efficiency increases as the compression ratio increases. Since there are always some losses and pressure drop in filling and emptying the cylinders, any way of getting more air into the cylinder will effectively increase the apparent compression ratio and will increase the efficiency of converting the fuel heat into power. This was seen on the dyno runs with an approximately 30 HP increase (10-15 % over 2100 to 2400 rpm range) and I assume no increase in fuel use. The other side of the coin is higher efficiency with the same HP production will result in a milage increase. Therefore, there could be some increase in milage at low power outputs as claimed. In addition, air flow improvements will reduce exhaust gas temperatures with the same fuel usage.
If this is so, then other air flow enhancements like mufflers and air filter changes might give some efficiency improvements to the other Cummins owners operating at less radical conditions (not full throttle drag racing, sled pulling, or dyno runs). I checked out some of the older posts and supplier web sites and found claims for milage increases with exhaust and air intake system changes.
I assume that efficiency and milage increases due to cam changes and different turbos might not be cost effective. Changes to the muffler and a BHAF might be paid for by the savings in fuel. One other benefit would be the reduction in exhaust gas temperatures when pulling that long 8 or 9 percent grade. The higher the altitude and/or the higher the outside temperature the more you have to back off to keep temperatures in check.
I am speculating that the maximum efficiency of the 12 valve at 1600-1800 rpm and maximum for the 24 valve at 2000-2200 rpm is due to the most efficient range of filling the cylinders with air. The 4 valve head will flow more air at higher rpms. If so, the efficiency improvements of cams, exhaust systems, and air filters might have move impact on 12 valve engines than 24 valve engines. I know I pull my fifth wheel in drive (no OD) at 2150 -2300 rpm which is considerably above the most fuel efficient rpm for the 12 valve.
If any of you kept good records of milage towing and solo before and after any exhaust and/or BHAF changes, tell us what, if any, milage increase you have seen. A 1 mpg increase whould be great to us who are getting 11 or 12 mpg towing an 11,000 lb, 12 ft tall porta-potty.
