MNTDR Annual Dyno Day at Hi Tech!
Ideas for a MN Charity Dyno Day
North Dakota Chapter Meeting
90% sure I will be there (not necessarily needing a dyno spot) but I will have a grill and some plates etc for those who want to bring their own chow. Does anyone have a tap and die set? If possible, I may be looking to drop an egt probe in time/weather allowing.
Matt
Matt
I have the correct tap, I may or may not have the correct drill bit in the edge box (if I remember I'll look). need a nice drill as there's alot of meta to drill out.
I make my living with dewalt 18v cordless in the winter, I'll bring the better drill, several batteries and a charger. If you can't locate the correct bit, let me know, I may have the correct size, or I'll be sure to pick up a fresh bit. Thanks Jason.
Matt
I should be able to make it , but I'm looking for a overflow valve [ local ] to be sure I get it before then and try to avoid shipping ?
I'm trying to find one in the T. C. area .
Matt
Found the tap and a drill bit that I used. heh, they were both sitting in my juice/attitude box for over a year and half now.
The drill bit looks in good shape, only used once. Bring some lube for the bit (tho, I didn't use any my self, but may help) and a magnet for the shavings and we'll get your EGT installed in no time flat.
Also, any wire ends and crimpers and tools for the electrical should be on hand. if you need any of that let me know, I just started a new "truck wire kit" recently with the addition of the FP guage and the rail pressure gauge that I hope will be here this week.
JFaughn said:
Hay Josh,
Ya I know but moneys tight and I think they get about 60-70 bucks
and I see em on the net for 35 - 40 .
check with cummins in White Bear Lake, their prices are usually pretty fair.
Bring what you got, I also have a small "wiring tool box" that I will bring, we should be able to get it together between the two of us. It also shouldn't require much (if any) extra wiring, its the juice box from Edge.
Thanks,
Matt
well you wont here from this guy for the next few days. i have a combine to go weld in the feild that snaped a drive axle i have a VP to deliver and install and i have to get my truck up and running, let alone the harvest activities at home... ... . :(
The Fat Kid
Andy
TurboTweaker said:
thanks josh. the old man went a shoved the tps down there throats and got a new one... . :cool: its good to send in the big bear somedays. :-laf
I can only immagine how that conversation went! :--)
attn. Spicy
Het Jim,
When do plan on heading west? Let me know if you want to meet up and 'mini-convoy' over to hi-tech, but you have to promise to take it easy on the go pedal, cause my truck is still stock. :D
Matt
Gentlemen!
I have great news! I just got off the phone with Neil from the DHRA. We are going to have some excellent prizes to give away this weekend!
I'll be getting them today... . I'll try to post something about what all we have when I find out what all will have!
JP
