"Modified" little fuse adapter?
silencer ring clip
"TDR LOGO'S" are headed your way!
Could someone please direct me to the link that showed pictures of a modified little fuse adapter? I did a search and haven't been able to locate it. Thanks a ton,
Loren
Modified Fuse tap
I just finished putting in an auxillary fuse block. I utilized a fuse tap for the trigger wire for the ignition on fuses. The fuse tap that i used was sized specifically for the little fuses that the rams have. You should be able to find these in larger autoparts stores.
Hope this helps.
Is this what your looking for?
It is LittleFuse’s Mini Add-A-Circuit. Check my signature for a link to their site. I purchased mine at Pep Boys.
Thanks to all those who've responded.
It seem though that some individuals had to "modify" their mini fuse adapter to get it to fit all the way in and had posted a picture of it afterwards. I had just wanted to see how they had done this modification.
Again thanks:)
TTT
I have one just like the pic above, but it won't fit right - I'd be interested in the mod's also.
Anyone???
Re: TTT
Anyone???
Had same problem as above . Look at place to plug in notice small bump or projection of plastic in middle , the body of adapter had to be filed or cut out to fit and prongs bent and filed to fit. Each different on will if needed will have its own mods to be applied . Hope this helps . Ron in Louisville . PS when pushing in body came apart had to glue it back with crazy glue . Tried to post before but it got lost in siberspace.
