Texas Diesel -
I do not know of a way to measure internal temperature of the VP44 except by the temperature of the fuel going in vs the temperature of the fuel comming out with the difference being the heat rise generated by the VP44. Marco says the VP44 internal input fuel temperature is one of the temperature values available with the proper reading tool.
Sort of like measuring engine oil temperature, radiator fluid temperature, differential fluid temperature, transmission fluid temperature. All are not the temperature of the actual component, but the cooling fluid going through the component. The component could have a very different temperature, but we ASSUME (and you know what assumeing is) the component temperature is reasonably close to the cooling fluid temperature.
How would you measure internal VP44 body temperature?
I think you are saying that in Gary's case he is measuring the EBC cover temperature and you are saying the circuit board may or may not be close to the same temperature.
Probably true if you measure the fuel temperature as well. Fuel temperature would not necessarily equal the circuit board temperature. Although the fuel is routed under the circuit board bay and used to cool the circuit board bay (as well as the rest of the VP44).
On engine shutdown both Gary and I flood the upper Vp44 area with outside air for a couple of hours trying to draw heat away from it and provide a sort of heat barrier for it. Not scientifically correct for sure, but a sensor mounted to that area should reasonably show how the heat in that area is rising or falling and the effect that the air flow is having in the general direction of the temperature.
We (Gary and I) each have a slightly different approach.
I am trying to cool the cooling fluid that circulates throughout the VP44 to try to get to the internal temperatures in general and the electronics bay in particular. My theory is cooler fluid, cooler component, then do your best to hold or lower the total VP44 mass temperature after shutdown.
My bench mark is 100* maximum fuel input temperature. The benchmark is purely a WAG, and just a value that if I can hold the input fuel to that benchmark (100*) then the VP44 internal temperatures SHOULD be well below the limit (by Bosch) of 160* fuel input temperature. (My first misting (see above) install will be this weekend. )
What would your ideas be to help with the longevity of the VP44 with respect to temperature?
Bob Weis
Bob Weis
