Well, I got the mister installed on both sets of fuel coolers. Another 5* off the fuel temperatures. I was thinking about the comment "the low hanging fruit" and decided to try to wrap this thread up, at least for me.
THe following are as I remember them, so take it with a grain (or pound) of salt.
OEM ff removal about -15*
VP return line back to the tank filler about -10*
Input to VP fuel cooler (mine with fan) about -10*
Fuel coolers on return line about -7*
Low pressure fuel pressurization system about +3*
VP presurization system about +5* ( the higher the engine rpm the higher the VP differential temperature in my case about 1* / 100 rpm)
The fuel tank seems to be about OAT+10 and fairly consistantly. Not sure why.
Towing does not seem to make much difference, mainly the difference in engine rpm.
Misting fuel coolers about -5*
With my previous system I had gotten the input fuel to OAT +10* and the EBC to about OAT + 13*. With misting the fuel feed cooler and the fuel return cooler the input fuel is OAT +5* and the EBC is about OAT + 8*. About the same relative temperature as before (just 5* cooler).
I drove for 2 hours in OAT 95* - 99*this afternoon. Fuel feed was right at 100* - 104*. EBC was right at 103* - 107*. One difference now speed seems to have more effect on better cooling. The 1* / 100 RPM starts to lessen over about 60 mph.
I got stopped by a phosphate train (80 cars long) for about 1 hour at OAT 98*. The fuel input temp went as high as 110* (12 differential) and the EBC went as high as 122* (24* differential). I think this tells me that frontal ram air under the hood is very important. My engine temperatures stayed at 180* so the engine fan never came on. I would liked to have been able to turn the engine fan on to see what that would have done. However if 110* is maximum fuel input temp and 122* is max EBC temperature then I am pretty satisfied with that. I figure the PSG is somewhere between those two values. (maybe a functioning hood scoop / vent could be very beneficial to lower heat?)
I put a 21 gallon commecial agriculture water tank in the bed and connected the pump and filter and misters described in a earlier post. The install was not bad. A little tight in some places, but over all not bad (of course if you go this route your own setup depends where you locate your components).
I am going to drive this for a while (several weeks) and see how it acts and reacts and see how the coolers load up or do not load up with road dirt.
I think this about finishes my quest for cooling the fuel. I can feed the VP with not much more than OAT degree fuel and that should keep the VP running well (I hope
), and that was the orgional objective.
I think overall what I found is no one thing is the silver bullet, but each thing contributes something.
I still totally endorse the after shutdown blower concept. When I got home tonight, OAT 98*, fuel temp 103*, EBC 106*, shutdown, max EBC temp went to 112* and started slowly cooling in about 20 minutes. The final EBC temp was OAT, but it only spiked 6* from run temperatures. I run it, I see it, I know in my case it works.
Good luck for others that try the same thing. I think I proved it could be done, but it sure took strange turns and you may not want to do add the water misting for only 5*, but at least we know about what the misting gain can be if you do that.
Good luck, Good hunting, I'll sit back and see if, or how, this thread develops. Who knows, maybe a totally different direction with someone's different ideas.
THANKS for ALL the inputs, everyone's thoughts and ideas, made this effort a very sygeneristic effort,
Bob Weis
