CORed "But here's the kicker... it is still hot enough to necessitate removing my hand in 3-5 seconds after more than TWO hours" and I think this is the problem with the electronics board. I am going to put a bilge blower in that side and exhaust air for as many hours as it takes to keep the electronics bay much much cooler during the heat cycle. The electronics boards seem (seem, not scientific mind you) to fail or go noisy when they are heat cycled one too many times. I am going to TRY to reduce the heat cycle peaks as much as possible by powered exhaust of under hood heat.
When I park the pre turbo is about 300*. WITH THE A/C OFF it takes about 2 - 5 minutes to get to 200* (maybe 220*, needle point is right on the high side of the 200* line on the gauge). It is not so much to cool the turbo, but to cool the VP and engine, radiator, intercooler etc. I think if I can shut down 100* cooler the latent heat problem will be easier to work with.
On the fp. I went to RASP when I went to vent line return for the VP. I actually have 2 vent line returns. 1 for the RASP & 1 for the VP. I did not want them competing or even interacting. The fp at the VP with the RASP is ALWAYS 14+. At stop lights to insure fuel flow I will go into neutral if I think I am going to be sitting for more than 30 seconds because the engine is not lugged down and the VP will see 15 psi at least just sitting there waiting for the light. I think the intank lp is not a Oo. thing. I know what the RASP will do and why. I can not say that for the in tank pump. I read what Bosch criteria is and the in tank lp does not in my mind meet the criteria.
I also think the fuel module has something inherently flawed. One is the return fuel is dumped right where the fuel pickup is, ie heat. BUT, in DC's defense, my 02 is now designed to operate in FL with a meticulous operator, ie Stanadyne PF etc. DC has to build it to work ANYWHERE with ANYONE driving. A lot of people swap vehicles every 3 - 5 years and that time frame is probably all DC is interested in. WE however want it RIGHT! and RELIABLE!, TDR member values are greater than DC's. WE want mechanical correctness! I think the lp tank thing is a patch at best.
Now I do not get into the VP/inj return line until it turns into steel line by the transmission. Look at my previous observations, I think the VP return line to the steel line is maybe 1/8" - 3/16" id. It is not much. I did not get into it at the engine because I thought that it may take some restriction to ensure it picks up heat from the VP. The return line on the side of the VP is WAY BIGGER than the line after the T. The steel line is . 31 od, and has the VP return line crimped INSIDE of it, then there is some wall thickness to the VP line. . 31 id - ~ . 06 wall thickness ~ . 25 id - . 06 wall thickness ~ . 20 id for the VP return line as it goes into steel line on the frame.
On the ECM pkg heat. It might have been designed to be bolted to the engine and designed to take the kind of latent heat. As I recall it has a lot of square surface area to sluff off heat. The VP electronics bay is way smaller in square surface area. THe ECM is also verticle so heat sluff should be fairly good. VP electronics bay is on top and not near as conducive to sluff heat. Just my thoughts. However I will take ECM temperatures as well.
I really think we are understanding the problem better.
Bob Weis
