Well, not sure about the correlation.
1. Keeping the fuel cool I think helps keep the Vp44 cooler. I can let the fuel temp go up and the VP44 EBC temp goes up eventhough the rpm and forced air stay the same.
2. After engine shutdown with no forced air the VP case will heat soak significantly higher than with forced air. I think that what the forced air on shutdown is doing is keeping the block heat OFF the VP44.
With forced air the case temp rises 5*, without forced air the case temp rises 30*.
Let's say you run your computer in an enclosed desk enclosure with the door shut and no outside air. The heat given off can not dissipate and the case and internal CPU gets hotter and hotter because it is heating the air faster than the desk can absorbe the heat. This happens at work all the time. We drill holes in the desk back to vent the air, and in some desk install forced air fans.
I see less temperature rise in the VP44 (and injector) fuel output temperature with case cooling than without case cooling. With case cooling I see less case temperatures, which I think would get temperatures to migrate from the inside to the outside of the VP44 to try to equalize the temperatures.
If the VP44 outside were higher temperatures than the inside then the temperatures would migrate from the outside to the inside of the VP44.
... "I think the blower is a feel-good step that doesnt effect the internal temp of the VP-44 much, if at all. As you cool the side of the VP-44 facing your fan the engine is sinking much more heat right back in... "
Not necessarily so,
Flooding the VP44 with OAT helps keep the engine block temperatures from migrating to the VP44 by providing a cooler forced air buffer around the VP44.
Try puting a temperature sensor on your VP44 right at the inlet. Measure the input fuel temperatures. Now go to the fuel return line and measure the return fuel temperatures. Now measure the Vp44 internal temperature (not sure how to do this). Now see what temperatures you are reading. We will compare OAT, empty, loaded, terrain. That should tell us if the forced cooling makes a difference.
I know when I have turned off the forced air everything else the same, the VP outlet fuel temperatures were higher (ie there was more heat internally being picked up by the fuel), the VP case temperatures were higher (maybe due to picking up engine block temperatures, not sure).
Turn on forced air, cooler, off, higher. The VP was doing the same work (rpm, load, gearing, fuel level).
Now if we could actually measure the internals of the VP44 that would be great. That is why I guesstimate about maybe somewhere around +20* to the case temperature to be the internal temperature. If anyone knows what the VP44 internal temperatures to the case temperatures are that would be great.
I have never heard of a ECU failing due to temp and it is mounted right on the side of the engine. Maybe designed correctly to handle the actual temperatures?
I have heard of VP44's failing. One vendor speaks of a redesigned electronics boards to try to prevent heat cycles. When my VP44 failed, run easily, no problem, run hard, problem. Everything was the same except higher rpm's and heat. I can see even now higher rpm's = higher case heat and I think I would extrapolate that to higher internal heat. If I can keep case heat low, then the higher internal heat should migrate toward the lower case heat.
Bob Weis
