Bob - and others following this thread - here's some shots of the latest "evolution" of my air system supplying outside air to my VP-44. I'm using a larger entry scoop similar to what Bob proposed a few posts earlier, and will now see what - if any - gains there are in cooling performance with the truck in motion do to ram air effect.
Here's the raw scoop and lower duct:
You will notice the "lip" at the upper edge of the scoop portion - that clips to the lower lip of the air dam on my truck.
Here's an underside view of the installed new scoop:
Pretty neat mount - with a single wire tie for insurance.
Here's a view from the front:
YUP, sorta ugly!
BUT, main issue, is it effective? Time and miles will tell if there is any improvement over the smaller scoop originally used - and this one CAN always be relocated back more out of sight under the truck, and still get good airflow.
REALITY CHECK!
Those who have followed this thread, have mostly done so out of curiosity and vague thoughts of MAYBE trying some of the ideas offered here on their own trucks, if the test results seem to prove out - MOST will simply read here, and do nothing.
Speaking for myself, but I suspect Bob feels the same way, I have NOTHING to sell, and whether or not any readers apply anything presented here is purely up to them - I don't profess, or plan to "prove" anything to anyone, other than by various test results and readings freely provided in this thread - if some here think these efforts are a waste of time, FINE - then don't use any of them!
We have been told directly by Bosch reps that these VP-44's rely upon fuel flow for both cooling and lubrication - but what PART of the VP-44 NEEDS to be "cooled"? Certainly the metal components don't need any unusual cooling - the difference between 50 degrees or 150 degrees is no big deal!
Some of the seals MIGHT like temps lower on the temperature scale - but still probably not unusually sensitive in the ranges normal in typical truck operation...
The internal computer, however, is another story!
A LARGE percentage of VP-44 failures occur, not mechanically, but purely ELECTRONICALLY - to the point we have seen several significant Bosch upgrades to the electronics in an effort to reduce heat related failures in those components.
The temperature sensitive solid state components inside the VP-44 are, in my opinion, by FAR the most temperature sensitive in the whole Cummins fuel system - and stand to benefit most by controlling cooling fuel temperatures - or any OTHER contributing cooling that might be supplied.
Fuel coolers installed to provide and maintain cooler fuel temps are easily recognized and understood - they work, and properly done, work well - but the remaining issue of under hood heat soak and radically elevated temperatures after engine shutdown are NOT improved by fuel coolers alone!
THAT, is where applying a cooling stream of outside air during, and for a measured period of time AFTER engine operation comes into play! And yes, I am firmly and fully convinced that cooling the OUTSIDE of the VP-44 will as effectively cool the internals, just as applying heat to the OUTSIDE of a pan of water will cause it to boil, or applying freezing air to the outside of a container of that same water will cause it to freeze!
Certainly, air is NOT as effective or fast a temperature controlling medium as fuel or other liquids, and takes more volume and flow, but it IS effective, or the cooling systems in our trucks are ALSO a waste of time, since the radiators and coolant are cooled totally by circulating air flow!
Thus, my approach with the air cooling system I am using - I've thoroughly measured operating temperatures of the VP-44 body under widely varying conditions, as well as the fuel lines entering and leaving the pump - the application of good cooling airflow has displayed a substantial and predictable cooling effect to the VP-44, and the measurable elements going in and coming out of it - it hardly seems logical or sensible to assume there is no related benefit to the internal electronics as well...
But like I said, if'n ya don't believe it, don't DO it - most wouldn't anyway, and I only post this stuff as info for those sharing my interest!
Now, the testing continues!
Oo.
