MOD's What MOD's would you do again and which ones would you not do again.
Towing with a HTT/64/13SS
2003 wont start when cold
Would not do:
1) 5" exhaust, good product but alot of drone w/ only 1 muffler
2) Street version of a DD, should have just got a 3600 or 3850 plate originally
Would Do:
1) Tst, no explaination needed
2) pressure box to smooth out the Tst
3) 62mm Hybrid turbo
4) Superlift
Best mod to date
1) Amp Research powersteps- expensive, but worth every penny
Would Do Again:
Everything in Sig Except
AR Pythons - Can't keep them polished, now they look like crap
Banks Exhaust, Aero, MBRP - Buy and MBRP system and be done...
Maybe SPS62... RCT is a little laggy, but no surge :)
Need:
Clutch
Brite Box
FASS Quiet 150
Another CP3
Water
Studs
Cam
A DANG EXHAUST BRAKE... SO AWESOME, WISH I HAD ONE!!
daytripper63 said:
I am planning on getting one of the new silent Fass and would like to know if anyone else is having the problem with truck running out of fuel at 1/4 tank?
I can run till the light comes on, its all in how you install the pickup tube. I have never ran out of fuel... furthest I have gone is about 10miles after the light came on.
The new pumps are VERY, VERY quiet :)
Do again:
TST/EZ stack
Line-X
HTT turbo
Pricol gauges
SRT pillar gauge
Pro-comp 6005 wheels
Husky floor liners in rear.
ATS stage V Trans
AFE and UNI filters both work well
Cool Blue hose.
Billet flex plate
modded CP3
Would Not:
FASS pumps 95 and 150. Too loud/can't hold FP (stand alone pumps)
Smarty even with several programs the light throttle wouldn't let the trans shift into second. I have a TV cable not solenoid actuated. may be problem?
ProComp Xtreme All terrain are fine now but the first 1k miles they felt soft as butter and truck was hard to control.
Partially building trans i. e. just a torque converter/vb. that will cost you in the long run.
running a straight pipe with stacks, sounds good till you have to drive an hour or more each way to work everyday.
Won't do again:
Cheap aftermarket mirrors
Least likely to do again:
MBRP exhaust
ATS exhaust manifold
Probably would do again:
AFE Intake
#10 fuel plate
Luke's Links (on tie rods)
Definitely would do again:
PacBrake
LineX
DD stage II injectors
3K gov springs
Centermatics
DDT transmission
Dipercol gauges
3rd Gen trackbar
DSS
Summit headlight mod
Rostra seat heaters
Intend to get:
Suspension kit (leaning towards Carli)
Snow water/meth injection
Actually I haven't done anything (yet) that I have really regretted other than the mirrors. If you have to replace the mirrors send enough to get a quality product. The cheap ones I bought vibrated so much you couldn't see objects in them.
Wouldn't do again:
MBRP cool duals (Look great and good fit/finish... too much drone towing heavy)
Bullydog Not bad, but would like to try Smarty/TST
Do again:
Mag-hytec diff cover for sure
Banks intercooler... exhaust for your intake, low end torque and EGT's do drop
2-3" leveling with 1" added to back
Bullydog outlook monitor
Would not:
Cheap Grill inserts: They feel cheap just looking at them. Rip Off. But they were cheap.
285 tires: Spent the whole 20,000 wishing they were 315's (wish I had seen that you can run 315's on stock rims before I bought these). Almost outta tread though. Dont know how that happened. :-laf
Edge/juice combo: Should have got tst from the start. I guess I didnt know till I got the "bug" though. I still like alot of the features on it though. Wish I could have gotten all in one. Personal opinion wishes tst would include more of the stuff that the juice has, i. e. easier to read, more user friendly screen 1/4 mile, 0-60... ...
Buy fuel preassure gauges over the phone without knowing what I wanted and what they max out at and how they hooked up (bleeding stinks go electric).
Rear-veiw mount tv that hangs from the mirrror: Wont hold up to hot weather and the added weight at all. Had to build a stainless mount that screws into the roof supports.
Alpine cd player: Dern thing skips a NEW cd half tha time. Think I'll try an Eclipse next time.
Whistler Radar detector: False alarms suck. It was on mute on the last 2 tickets (my fault kinda). Illinois cops just like me.
Try to drive a CTD through any mud or sand or think that limited slip helps the four wheel drive at all.
Try a 3rd gear launch the day before a long trailer haul with a stock clutch and egde on 5/5. Nah never mind I still wouldve done it. Got the woman to release the money for the SBC, " I have to have it for work. " :D
Would:
Banks Technicooler: (got my ins. to include it after I hit a deer, so in the same situation, yes, but I didnt feel any seat of the pants feel or gained mpg though. Doesnt do much for a stock truck. Still hoping that the future mods will net me some "unnoticed" benefits.
Magnaflow muffler: no drone just wish it was 5" with stacks(theres that drone). Never even wanted stacks till I planned on ordering a smarty though. Im figuring I will smoke too much while pulling with the juice/smarty stack. Which I'm still hoping that stack works.
Intake:Custom built tube and K&N works fine for me, 50,000 still aint cleaned it.
Line-x: Have had it on a jeep and 2 trucks now and I still like it. Just wish it would hold up to the abuse I put it in (it WILL gouge). Still better than nothing (rhino).
SBC DD 3600#: Even with my luck (having one of the few that have forks "pop off") Have someone install it that you trust if you dont have time or means to do it yourself. I still love my rattlin, clangin, SBC. Sure I would get one with springs if nothing gets sacrificed for a little noise.
Toyo: Wish the M/t 315's werent so pricey. May look for another "E" tire in a 315 before I spend that money. Anybody got ideas???
Fass 150: Loud but I did gain mileage but lost some distance. Now I look for a station when the overhead says 100dte. Need 2 take it down and see if the pick-up tube can be lowered more. Installer was a hack and I shouldve done it myself.
BD Short shifter: Makes the hand shakin less painfull all around. Plus the bend I put in it torward the driver helped tons.
Silencer ring mod: Love that whistle :-laf
Prodigy Trailer Controller: Works good, worth the extra money
Reflexxion Hood: Looks great but make sure you have the bodyman fit it on the truck. Little larger gaps than factory. Kinda hard to make changes to the fit if you have them paint it to your body color and install it yourself.
Have dealer turn-off the automatic locks right away. Rear passangers hate it almost as much as when I need to get anything out of the back seat.
Build a lightbar out of stainless thats capable of throwing a yank strap around while attatched to a heavy trailer and being pulled out of heavy snow by a full size grader without bending. Mount it to the tow hook area with 1/2 plate and use good bolts.
:-laf :-laf :-laf Thats as bad as the Cop I passed doing 75 while flashing my lights at the guy in front of me driving 55 in left lane, obviously he knew about the highway patrol in the right lane on the other side of the Big rig in the middle lane :{ I hate when that happens
Yeah well I think california cops like me to. I was doin a little high speed drivin behind a carload of women doin the same speed but I got the ticket and im pretty sure I didnt look better than them... ..... then again the cop did seem a little light in his loaffers. :D :D :D
I was goin 90 in visalia (visalia... . it even sounds like an affliction)
Would do again: I just installed an EZdown (helps control the lowering of the tailgate).
Real easy install. All tools needed are included except 1/2 wrench or rachet, which most people would have.
Guages. Even though they are still sitting on my bench in my garage. 1/27/07 is planned install date.
Rhino lining: I had on my previous truck of almost 8 years. One of the first things I did on my new truck.
When I have more time I will come back and edit this.
Oh yeah I forgot
Condenser guard: Good idea but the one I made out of stainless for the factory intercooler doesnt fit with the new Banks intercooler which is wider.
Vent Visors: are a great idea but I always hit my cigs on them as they are goin out the window.
Not
  • High beams in the bumper... sure they work awesome and will probably stay, but off road lamps on a light bar would work better while keeping the fogs.
  • Step Tubes
  • SPA Gauges
  • 5" Exhaust
  • Cool Blue Hose
Do Again
  • ISSPRO Gauges
  • Linex
  • De-Badge
  • Fender Flares
  • Mud Flaps
  • Sport grill insert
  • 03 Laramie painted grill frame & chrome cross
  • Remove rear blocks
  • Custom wheels
  • Dash kit
  • PDR Cam
  • Fuel tank filler vent mod
  • Fuel tank roll-over valve filters
  • Condenser edge guard
  • Tone ring mod
NOT DO.
  1. Airaid MIT.
  2. Drill holes in my stock intake.
  3. Cummins logo floor mats from Geno's. They are "GARBAGE"!
DO Again:
  1. Line-X.
  2. PSM Intake.
  3. S&B Drop in filter. (Not one spec of dust gets past this filter). 8ply.
  4. Door Molding.
  5. Rear wheel well liner.
    Cool Black Hose.
    Condensor gaurd
WOULD DO AGAIN
TST, WISH I HAD THE R49
EDGE EZ
TS RAMIFIER, BUT ONLY WITH BIG INJ AND MODDED CP-3
II INJECTORS
MODDED CP-3
DUAL FEED LINE
CUSTOM CONNECTOR TUBES
TWIN TURBOS- WAY BETTER DRIVABILITY THAN A BIG SINGLE
SUPERLIFT SUSPENSION WITH MY MODS :-laf
BILSTEIN REMOTE RES SHOCKS THEY RIDE NICE, I DRIVE IT LIKE A RALLY TRUCK. . :-laf
POWER BY POOLE BILLET SPACER BLOCK DELETES GRIDS AND I LIVE WHERE ITS COLD...
HURST SHIFTER
610 CYLINDER HEAD ON 03 HO
STOCK COMMON RAIL PISTONS, THEY ARE A GOOD PISTON FOR THE PRICE
ARP STUDS
ROKKTEK CRANK SENSOR FULL ADVANCE
ATS 3-PIECE SECOND GEN EXHAUST MANIFOLD
CP-3 INLET PRESS GUAGE IS A MUST, HELPS TROUBLE SHOOTING
SLY DRIVELINES CUSTOM FRONT DRIVE SHAFT
CUSTOM SOUND SYSTEM
HUSKY FLOOR LINERS
TINTED WINDOWS
DUAL 6 INCH STACKS
5 INCH EXHAUST
37 INCH TIRES, LIKE THE BFG MUDS THE BEST, THEY LAST THE LONGEST THE WAY I DRIVE, WISH THEY MADE A 39
SNOW WATER METH
ADD A SECOND LIFT PUMP IN SERIES WITH THE STOCKER IF UNDER 600H. P.
FASS 200 WITH FILTERS AND BIG LINES, NOISEY BUT IT GETS THE JOB DONE AND THEN SOME
CERAMIC BRAKES ON THE FRONT AND SEMI ON THE REAR, TEARS UP ROTORS BUT WILL STOP A LIFTED LOADED TRUCK
GREASABLE U-JOINTS ON REAR DRIVELINE, THEY ARE BIG ENOUGH TO TAKE ABUSE WITHOUT BREAKING,
CHROME TUBE STEPS DOUBLE AS ROCK SLIDES
DITCH THE RAIL RELIEF VALVE- I BROKE 4 OF THEM AT 400 PLUS A PIECE
PAINT THE UNDERCARAGE- KEEPS THE RUST OFF
BUILT A QUICK RELEASE LINE FOR FUEL PRESSURE GUAGE, EASY TO MOVE OUT OF THE WAY
MODIFIED BATTERY BOX, I HAD TO GO BACK TO TWO BATTERIES
MODIFIED INTERCOOLER SUPPORT- FASTER REMOVAL OF INTERCOOLER
CATERPILLAR PLUGS ON HOME MADE HARNESSES
I THINK THATS ALL FOR NOW:cool:
WONT DO AGAIN
VAN AAKEN DURATION
STOCK 03 HEAD AND BOLTS
STOCK MODDED TURBO
6 INCH STACKS WITH A SINGE, BUT WOULD DO WITH TWINS, I USE THE LOWER TURBO FOR A MUFFLER
STOCK CP-3
SINGLE DISC CLUTCH
AR PYTHONS AS MENTIONED BY SOMEONE ELSE WONT STAY POLISHED
LEVEL LIFT
4 INCH LIFT
NON RES SHOCKS
4 INCH EXHAUST
GREASABLE FRONT U-JOINTS--- EXPLODE ON COMMAND
STOCK FRONT DRIVELINE-----EXPLODE ON COMMAND
STOCK BALL JOINTS SUCK
SUPERLIFT SWAY BAR LINKS BEND WHEN FOURWHEELING THE TWISTS
STOCK REAR U-JOINTS HAVE TO PULL APART TO GREASE
HAVE MY KIDS MOM BACK#@$%!
DEAL WITH HAISLEY MACHINE#@$%!
BUY AN EXTENDED WARRANTY:mad:
BUY LITTLE TIRES
RUN A 16CM EX HOUSING ON TOP TURBO WITHOUT NITROUS
LOTS MORE IM TIRED OF TYPING
WANT
ADD ANOTHER CP-3
RUN A PHAT SHAFT 64 ON TOP
MORE LIFT
22 INCH RIMS WITH 40S
PULLING BARS
NITROUS
DOUBLE DISC 4200 FERAMIC
UPGRADED HYDRAULICS
MOOG BALL JOINTS-ON THE WAY
DUAL STEERING STABILIZER
LONG ARM TRAILING ARMS
A MEGA CAB
AND A BIGGER GARAGE;)
What's everyone got against the BD Power pup? hahaha. just curious. Is it that the smarty is so much more adjustable (pressure on/off, etc. )?
Also, I noticed quite a few people have the 2" leveling kits. I have been SO close so many times to installing the spacers (cheap way out, I know) on my truck. however, the fact that the rest of the front suspension geometry remains untouched (aside from the adjustments made during an alignment) scares the heck out of me! maybe it's just how I was taught to think as a mechanical engineer... . but the fact that the spacers cause the stock suspension setup to flex and move in a totally different way than what was intended scares me.
I jacked up the truck and we do have a lot of extra room for extension in the stock setup. If I do install the spacers, i will loosen all of the pieces that have rubber grommets and retighten them at the new ride height to prevent ripping. However, I'm still afraid of the increased wear on the front end components due to the 2" increase. ANY INPUT??? I wish I could persuade myself that I won't see any increased wear with these simple spacers, but hey. . I plan on getting buried in this truck and want to keep it around for a long time!
Any thoughts are welcomed! TIA!
NOT
-terra grapplers
-bully dog triple dog
-aeroturbine
Have worked great, but should have done different
-AFE... ..... I would do a dry type filter second time around
-con ofe... Shoulda went dual disk or FE
-banks 4". . Shoulda went 5" from the start
-Fass 95... . Had to buy the Walbro 392 to get enough fuel to the new CP3
Wouldn't trade
-TST
-DDP 90's
-Pacbrake
-Cepek Fun country ll's
-Motoblue 5"
-Silver bullet
-II's CP3
I second not spending the money on the aeroturbine again. its cool to see the stainless turn gold in some spots but i bought it to get the heat off my back and it was just a waste of money. very very slight change in quietness from straight pipe. the only difference is my buddy cant hear the lopyness of the cummins from his backyard half mile away when i fire it up. he can only hear me fire it up and hear me running it now with aeroturbine. also my girlfriend and her dad can still hear me 15 minutes before i get to there house. next time I would consider stacking mbrp's to shut up my 7" stacks.
When i went to buy my truck I looked high and low for a fully loaded dually with auto and black interior. at that time all i saw was 6 speeds. now look tommorow morning i will have a 6 speed coming to my house for my truck. shoulda spent less money and bought a truck with 6 speed first time around. also after 1st 48re I went through brunt up I shouldnt have spent around 6 grand on another modded one.
WOULD DO
Train Horns!!
BD short shift kit
Bent shifter
H2 Wheels
BOMBed high beam switch (probably #1) :cool:
Willy's Whisler intake
Tough Country running boards
Spooled Up's Tank Vent
WOULD NOT
Ranch Hand Bumpers (poor fit & finish)
All I can think of at the moment
Did you modify your fuel inlet from the Tank??????
If you did - then you lost any reserve that sits in the fuel pump module as they requested that you "Knock out the botom"... I did that and regret it... . if you are on a steep hill with low fuel - for any duration - the fuel will run away from the pickup and you're out of fuel... ...
