The BOMBin has begun...
Installed gauges, adjusted the vavles, moved the stock plate all the way forward, and installed a homemade vavle to control the wastegate. We installed a needle valve in the vaccum line to the wastegate, just behind the pump. Before we moved the plate, with the wastegate valve close, max boost psi was about 25-26. . After the plate was adjusted the max boost psi was about 35-36 psi. With the needle valve about one turn open max boost was about 32psi. Last week someone asked about the EGT's with the stock plate moved. . with the plate all the way forward, the highest EGT's we saw were about 650-700 post turbo. . This was during some hard runs. (This was with K&N, no CAT and a free-flow muffler. )
Thanks for all the help from the board. . after all the reading it sure made the installs easy. . Thanks. .
Bryan. .
BOMB truck was a 96 3/4
http://albums.photopoint.com/j/AlbumIndex?u=18303&a=98159&f=0&vt=vp
Bryan. .
