zstroken said:Here is the plagueing question, and maybe you already answered it. Don't feel you have to, but you mentioned you had plans to build it bigger and badder, what happened to change your mind?
DRadzierez said:I dont think you seen the last of bbd.
ChrisOlson said:MTomac, I re-read this thread up until your post--not 1 neg. comment about the d max, and just like the BBD and his break down, you too will break down.
If you look at the join dates, BBD has been around here since 2000. You show up on the boards in 2006. BBD had more than likely 4 times the the competition hrs on his Dodge CTD than you have on your d max. Let's see where you are at in 4 years.
I am not bad-mouthing your D max. You have an obvious bone to pick with the Cummins people. Also, you have done a great deal of research and have taken the D max to places it was not meant to go. Your formula for high hp and torque works, and good for you. BBD was and is an Icon here and admired on tdr, and I am sure that when your D max finally throws the rod or melts down, BBD will have more class than to post one-line negative comments about your d max. My apologies in advance for offending you.
Chris
Chris
MTomac said:Also, nothing against BBD but we have a ton more hooks in the midwest than he has out in CA. I have well over 150 hooks (100 in the last two seasons) and over 200 1/4 mile passes on my truck/engine which also has 113k miles on it.
Jim Fulmer said:Scott just did what I did 2 years ago with my old motor, I knew it wasn't perfect but didn't have the time or money for a new one so I kept running it. With all that I know now and the resources available I would have just rebuilt it.
zstroken said:BBD or scott behind the wheel of a pulling truck??
jwilliams3 said:I think Tomac has something like 150+ pulls on his truck. Heck I only have like 30+ in 3 seasons of pulling.
Forrest Nearing said:I certainly understand that, but I was under the impression that the engine you replaced was a well worn stocker... whereas his was a high dollar "built" engine...
We would be lucky to get a dozen pulls a year out this way, and BBD was at the top of its class out here untill the motor got hurt.
Hammer said:BTW. .
Was it just me or did it seem like Diesel Power catered to the Chubbie owners so they could win and allow them to sell more aluminum can motors?.
