Mounting Gauge in Ashtray??? Anyone done it?
Ditching overload springs and spacers= WOW!
How to ID the new thermostats?
<font color=blue>Been tossing idea around in my head on which gauges I want next. I am pondering a Dual SPA Digital gauge for fuel pressure or another EGT gauge post turbo for shut down. Has anyone successfully mounted a gauge in the ashtray (might as well use it for something) I think this would be a good out of the way place for a dual fuel pressure SPA digital (nice out of the way place easy to conceal since it won't match my UltraLites I have everywhere else, then I could put the Post turbo EGT gauge in the cubby next to the radio? Any ideas or comments on mounting in the ashtray... . please share.
I currently have AutoMeter Ultra Lite EGT, Custom 0 to 50PSI Boost, and transmission temp which will be mounted on the dash in a triple gauge pod #15002 Autometer. Which is the reason I wanna hide the SPA Digital fuel pressure gauge. Also any pictures will be helpful. Thanks B. G. Smith for the reply.
  • <font color=blue>
  • Eric D. Howard - #ad
    - BOMB'er! - #ad
    - TDR Member since April 8th, 2000
  • 2001 Dodge Ram 2500 HD 4x4 SLT Auto Reg cab Cummins Turbo Diesel 4. 10 gear ratio LT265/75R/16 tires
  • Patriot Blue Pearl Coat, Agate interior, Leather seats EVERY option, Silencer Ring AWOL</font>
<font size=-2>
[This message has been edited by KatDiesel (edited 07-24-2000). ]
Yep. Got my EGT gauge mounted on a hinge to the two screws in the top of the ash tray, I can tilt the gauge up and still get to my valuables in the ash tray.
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Rancho 9000s, bug shield and window vents, black vented 5th wheel tailgate, 100 gal. aux. fuel tank.
[This message has been edited by B. G. Smith (edited 07-24-2000). ]
Hummmmmm eric... somebody give u that bright idea?????????... JB
99 Quad,Long bed,4x4, SLT,Auto,K&N,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump, Suncoast coverter,BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, "true" Jet-Hot Coated 5 inch exhaust from turbo to tail pipe(over the axle)Borla shoot-out muffler,DD stage 3 injectors,4 wire Blue Box,HX-40 16cm2 and ATS exhaust manifold at Jet-Hot for there 2000 series coating(Gray), Valentine 1, EZ-pass
<font color=blue>Well I am sure with ALL the gauges you are currently running you gotta put them whereever you can fit them! Was gonna email ya and ask ya about all your locations when I got home from work today. I want to put the SPA Digital in the ashtray because I can close it and hide it, besides don't need to see it all the time. How did you mount yours?? I want the ashtray to still close up like normal.
Got real busy in the middle of this post. . I'll finish later...
LOL. . i knew that would set ya off... member am not your banks buddy. . <~~~lmao... I have my pesky Blue Box in the ash-tray... i used one of autometers 2 gauge panels and mounted it right near my gas peddle and as tight as possible to the airbag control. . aleast thats what i think it is. and i even used the crappy Dupont dye on the the gauge panel... lol... . JB
<font color=blue> I was typing that post up from work and right nin the middle of it I got real busy... so I couldn't finish it.
I remember ya saying you had your bluebox in there cuz I said the PE wouldn't fit... so you confused me for a bit. LOL
I just wanna figure out the best way to mount a single gauge in there is all... so i can close it out of sight... then open it when I need the info.
Scary thought when I start thinking... ... ... . #ad
