D
DPellegrin
Guest
Gentlemen:
With all this re-engineering the location of the batteries as well as adding disconnect switches, etc. , has anyone performed an actual voltage drop test on the starting system after all this surgery? It seems to me that moving the batteries further from the starter would require larger cables to maintain the manufacturers' voltage drop specifications. If the voltage drop is greater than specified you are significantly increasing the stress on the starter motor.
Regards
Regards
