mpg ?'s..
transmission abnormallity?
Reckon I'll give my 89 to the church....
therabbittree
what does every one else get with their early dodges. . with autos. 727 3spd
i run a 89 307 rears 1 ton srw 4x4 stock engine with some recent mods i did k&n cone filter (no factory airbox), wide open exhaust no muffler just 5" pipe exit side of bed from before muffler. . i just got truck recently about 4 tanks ago haha. . 125k on it. . i have not gotten any good mpg. . 15. 1 mpg and 13. 3. . sucks i think i need to swp to a stick transmission. . 6 spd or something i have no tach dso i can't give ya rpm at cruise... what is the average for a truck with my specs. . i plan on bombing it soon.
thanks
\x/ hillfolk!
Deo Read
30D 81093
My '93 1-ton 4X4 Club Cab 5 speed with 4. 10's has gotten no better that 14. 5 and averages 13. 5 PERIOD. This has been the case from bone stock to current status. The mods have NOT affected mileage but sure have put some power in POWER RAM.
'93 W350 Club Cab, Bright White, 5 sp. , 136K, Factory Options: LE package, 4. 10 Limited Slip, 7600 lb. rear springs, tachometer, front stabilizer bar. Mods: Banks stinger plus, Linex bedliner, 25,000 lb gooseneck ball, 10,000 lb receiver, Tekonsha brake controller, POWER WAGON injectors-WAY faster than stock!.
My 93 2 wheel drive with auto and 4. 10 rear gets about 20 empty on the freeway, about 18 around town. When towing about 6000 lbs, average about 12. I don't drive easy, especially since the mods. Love to feel that push into the seat! #ad
Stan
93 2WD extended cab, Banks Power Pack, K&N Air Filter, PW Injectors,Auto w/4. 10 rear with limited slip, US Gear Exhaust Brake, 31/2" Exhaust, 5K air bags, Boost/Pyro/Tach Gauges, Green/Silver, new 40-20-40 bucket seats, 149K
Hey Hillfolk,
Before I got my '89 totaled for me, it was getting about 18 to 20 mpg. Dropped down from 21 to 23 when the state went to "clean-burn diesel" That was in a 1 ton 4x2. I picked mine up a little when the pump shop replaced the worn out shaft bushing. They said not only was it leaking but it was also throwing off the pump's performance.
Best of luck, Jones
I get about 590 to 600 miles out of a topped off tank on ALL highway travel. . around town milage i can go about 450 if i'm lucky... cuz' i'm flintstoning it around all the time at stop lights. . with all this extra power though it's still gets awesome milage. . not much different than stock milage
Greg's 1993 D250 4x2. . 5-speed. . extended cab. . longbed. . bright white. . tinted windows. . 4-inch stack through bed. . K&N air filter. . holes in air box. . 143,000 miles. Tweaked pump. PW injectors... 12CM housing in real soon. . {thanks Piers}. "The Phantom"
15. 5-16. 5 empty. I haven't had a chance to tow with it yet though.
'90 LE W250, 727, 3. 07, Line-X bedliner, 140k miles,
14 loaded 10500 lbs camper
18-19 empty 93 1 ton 4x4 ext cab
3. 54 gears
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach soon to be in. Its loud and goes ok, for a 93,only beat 1 pwr strk furd. 2 optimas,
love driving it!
I averaged 20 in the 92 I sold my mom. Shifter in the wrong place. Need to be on floor. 2wd club cab dually, auto, 3. 55. Got 22-24 all hwy
Daniel's current truck: 1993 W350 club cab, 5 speed, treadplate aluminum flatbed, 4. 10 rear end, straight pipes, K&N, "slightly" tweaked pump. ISSPRO color coded pyrometer and 50psi boost guage. NRA Life Member (since age 12) and d@mned proud of it. IRBCTS.
I just had a thought. Would a bad lift pump decrease mpg? When the one went out on my 92, I was doing a mix of big and small loads, empty, too, so mpg varied. If the pump was not getting it to the inj pump, would it cause air to get in system, or just no pump hard enough? Mine is leaking a little, and I have the same problem. Any thoughts on mythought?
My overall mileage on my '93 for the past 127k is 18. 34 with a high of 23. 65 empty at 55mph and a low of 9. 9 towing at 65mph into a 35mph headwind. Most of these numbers are with the Getrag transmission. Since my switch to the NV4500 it seems slightly better. I'm running 3. 54 in the rear diff. and am 100% synthetic on all lubricants.
Happy Trails
1993 250 4X2 - Banks Power Pack, BD Power Injectors, K&N Air Filter, 6 gauges and tweaked pump. 27lbs boost unloaded.
Horton fan & NV4500 5 speed.
TRT,
I'm getting 19-20 @ 70-75, 22-23 @ 62, and
twice with a tailwind 25 @ 58mph(on cruise control). I wonder if there's more mpg to be had with optimized pump timing?
93 Maroon/Gold D350 CC Dually,5sp,LE trim, A/C,Raven cab height w/contractor side windows, PW inj. , K&N in OEM housing w\altered added inlet, class IV receiver hitch, Maroon cloth 60/40 '97 F150 bench seat, KYB shocks,& behind the seat,not yet installed: Moog upper & lower ball joints, PST poly graphite upper & lower control arm bushings and Praise Dyno Brake pads & shoes.
Around town stop/go I get 17. 8 to 18. 8 mpg.
Highway is better at around 19. 5
This is all running empty. If I get a little heavy footed around town then its down to about 17mpg. I'm still tweaking to get the right combo for overall performance and economy. (I think thats an oxymoron)Kinda like military intelligence. j/k
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar,Dual Shock Front Stabilizer,BD Injectors,31/2" Mandrel bent exhaust,16cm 'Hot End',Modest Pump Tweaks/Timed,K&N Air,Isspro Pyro,Tach,transmission Temp,Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots. 97,000 Kms.
I used to get 20. 7 mpg religiously on my 92 W-250 no matter if it was highway or in town solo. When towing a 26ft travel trailer I got around 17 mpg. I have recently installed a tall camper shell which has cut my everyday mileage down to about 18 mpg solo. This is with a 5 spd 3:54 and 300K
Mark Singer
31D 81158
I used to get 18. 5 mpg before the 4" lift and 34" tall tires... now I get 16. 9 mpg, still pretty good IMO.
later.
Dan Powell '93 club cab 4x4 4" lift, 315 75 R16 MT's
'87 Buick Turbo T
11. 52 @ 117. 5 mph
I have kept track of all my fill-ups and mileage since I bought the truck in 1992. Average mpg (US) is 18. 21 - most of my miles are put on aroung town. Best highway miles (empty) 22. 29 (65-75 mph).
92-LE,4x4,5spd,3. 54,Borgeson steering shaft, Tach,Isspro Pyro & Boost, 16cm2, PW injectors
About 21 MPG combined city and highway. Hauling my tag-a-long trailer about 18. Not having OD on an auto probably eats your mileage.
J-eh
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs. 237,500 miles (380,000 Kms) 7850 Hrs.
Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics
I was getting 14. 5 to 16. 1 when I had the 3speed in warm weather. Just finished my first tank on the 4 speed and got about 19(speedo quit working for about 130 miles) running in -12 to +30 degree weather running back and forth to work. Can't wait to get this baby on the highway again.
89 w250, 47rh trans, cleaned up exhaust, Dynomax bullet muffer, 3" lift
Fuel Mileage
Bought my 93 D350 Dually CC 3. 54 5-spd in Jul
2001. Get a solid 21-22 on the highway with
cruise contol set to 70mph (A/C doesn't seem to have any affect on MPG) mostly in the delta
flatlands . Around town seems to be 17-18 depending on use of liberal foot fogger.
Planning to upgrade to 4" exhaust, 14 CM turbo housing, POD injectors, K&N filter, opening up filter housing, advancing timing in the 1. 35-1. 5 area. Want to rebuild front end and fix the
cowl cracks prior to upgrades though.
